https://www.marinepartseurope.com/en/volvo-penta-explodedview-7749307-44-10670.aspx
Replaced my gimbal bearing and bellows over the weekend as well as some other general maintenance on a Volvo Penta dp-sm 1.95 outdrive. When reassembling I didn't realize it, but I left off the water passage seal (part number 81 in the link above). I ran the boat for a bit yesterday and it ran great. How important is that seal? I'm not even sure what it's supposed to do... It goes around the water pickup hose so you're pulling specifically from the holes at the bottom of the drive when it's installed. If it's not installed, you're pulling in from around the hose (a bit, maybe) as well as from the normal holes in the drive.
I can obviously remove the drive and fix it, but my boat stays in a lift behind my house. If it was already trailered--no problem. But having to trailer it, pull the drive, and install the seal is kind of a PITA, and it didn't seem to affect anything yesterday. I'm mainly just wondering what the thing even does, and how important it really is...
Thanks!
Thanks!
