The subject pretty much says it all. I zoned out and to top off my gear lube location I poured in the bottle I had in my hand that I didnt realize was actual quicksilver engine oil. I ony poured in about 1/3 to 1/2 max of a quart. Is this a problem? There is a high ratio of gear lube to engine oil in there (not sure without checking manual which is in my boat at marina). Will things be fine? Any danger leaving as is without redraining the gear oil and filling up? If there is, can I just pump out about a quart of what is on top of gear lube container and swap with the correct fluid (gear lube)? I ask this as there is possibility gear lube and engine oil dont mix righ t away and I can still save it.<br /><br />Thanks and please help!<br /><br />Patrick
