Acetone
1983rinker
I can use this to remove old carpet glue?? It will be safe for my fiberglass i think???
drewpster
Re: Acetone
I know it wont hurt the fiberglass but it may not do much for the glue. Depends on the glue that was used. It certainly wont hurt to try it.
1983rinker
Re: Acetone
Not much glue left on a 23 year old boat when i pulled up old carpet. I want to paint sides,(will not have carpet) and a gray carpet on floor with cream white seats.
scooper77515
Re: Acetone
Acetone WILL eat the fiberglass. you may not see it disappearing, but it is.
Don't believe me? Wipe acetone rag on the gelcoat and then look at the rag. Got white all over it, doesn't it...?
Won't see it as well with clear fiberglass but same thing is happening.
sprintst
Re: Acetone
I know mek Methyl Ethyl Ketone works really well for eating the glue but not sure about the gelcoat.
scooper77515
Re: Acetone
Straight MEK? I wish I had known that before I had used a dual-action sander on my car and my boat...:(
Bob_VT
Re: Acetone
Use a cup brush on an angle grinder and it will eat the glue up
1983rinker
Re: Acetone
I was doing that today. But it was digging into the glass to much, so I went softer on it. I got most of it.
Tail_Gunner
Re: Acetone
Yes read that with clarity....sadly no chemical will let you wipe away glue..actually acetone flashes for to quickly aka its gone in a flash..Man up get the grinder out and have at it
Oopps try gettting a 6" adapter use 36 grit paper and then have at it...;)
ondarvr
Re: Acetone
Acetone won't harm the resin or gel coat, at least not when used in this manner, if it helps to remove the glue its OK to use.
scooper77515
Re: Acetone
It is easy to tell if it is. Just look at your rag and see if there is any of the resin/gelcoat on it. If not, keep at it.
I try not to hit any one spot for more than a swipe or two. Keep at it too long and you will see your fiberglass appear on the rag, and your nice glossy coat may be dulled a little.
Yacht Dr.
Re: Acetone
Dont worry about Acetone on your gel or your glass.. Acetone Will not hurt/attack it in Any Way. If your nice glossy coat is affected with an acetone rag..then its just wiping away some crap stuff and not the gel :)
Try the acetone on the glue and see if it works..some glues react to different solvents but Acetone on poly Will not hurt Anything..
I dont see how a brass or other wire brush as Bob said would dig into the glass..unless its bogus glass.
Id do the same as Bob said .. wire brush on a 4.5" grinder ( using ear muffs and safty glasses ) 30 min your done..
If you decide to do with solvent..then shave and wear a respo !.. gloves etc. ( wear a respo/ears and eyes no matter what :) ) .
YD.
ajgraz
Re: Acetone
Another chemical option is a stripper containing methylene chloride. That chemical will eat just about any paint or adhesive.
Another mechanical option is a flat wirebrush on a rotary drill. May take a bit longer than an angle grinder, but is less likey to eat up the glass.
bear_69cuda
Re: Acetone
I used a cup wire brush and grinder on my deck... I also used MEK where I couldn't reach with grinder. Make sure and use a respirator with any solvent!
1983rinker
Re: Acetone
Thanks all, as you see I'm in the working on my floor. I want to make shure my sides are clear so I can paint. The floor I will carpet. Witch I got pritty good and clean. I just want do it right. Thanks for all info.
wambs8
Re: Acetone
Try a heat gun and putty knife. It should get most of the old glue up.
Dave
Hoggar
Re: Acetone
Try a Pinstripe Removal Disc it will supposedly take off the glue with out clogging and wont
be too harsh on the resin. Never tried it before but its suppose to take off the tape and glue
with out hurting auto paint.
