Acronis True Image Home 2009?
Boomyal
I have an unopened copy of it. I wanted to use it on my wife's new Win 7 Dell Laptop. I have cleaned out the fluff that comes on it and I had to have Dell do a laborious install of an updated touchpad program and drivers. The one that came with it did not have provisions to disable the touchpad when an external mouse was installed. This was no easy job and if I ever had to reload the OS, I would have to go thru Dell, at my expense to have it reloaded.
Now that the computer is clean and fresh I wanted to do the mirror image thing. Problem is, the Acronis 2009 does not show Win 7 on the box. Will it still work?
bruceb58
Re: Acronis True Image Home 2009?
Acronis says that it is officially not supported. I know I use 2011.
It's actually good that you posted this. I looked for my images last night and I can't find them!!!!
Boomyal
Where did you have them? On a disc or a drive? ...and if you ever need to reload the image(s), do you just load them on a clean drive like you would a new OS?
bruceb58
They would be on another drive. Yes, use Acronis and the saved image to create a new partition on your new hard drive.
PiratePast40
The cloning portion of Seagate Diskwizard used to be Acronis. It was the exact same program. Not sure if it still is, but if so, it's available as a free download from Seagate.
MTboatguy
What model of Dell do you have Broom? I can turn the mouse off and on in my Wife's dell, in fact you should be able to go to the mouse properties and specify that the pad be disabled when an external USB mouse is plugged in, also if it is a microsoft mouse, you need to install the drivers to get this function to work correctly.
MTboatguy
All of the major drive companies have programs for free that will clone drives.
bruceb58
Will they create an image to be used later though?
I was also able to turn off the touchpad on my GF's R15 she just bought.
MTboatguy
Bruce,
I was able to clone a segate drive that I just bought a few weeks ago, then reinstall the image on another segate that I picked up yesterday, went from a 750 gig, to a 2 TB drive, set the 2 TB as primary and everything booted up just fine. I used tools that I downloaded from segate.
bruceb58
Bruce,
OK...was wondering if the free software actually created the image file.
Boomyal
It's a new Dell Inspiron 15R. I thought it would be good to clone the drive before adding programs and transferring files. I used a Logitech wireless mouse on the laptop. It worked just fine. However the touchpad program did NOT have the checkbox to disable the touchpad when an external USB mouse was installed. Also the FN/F3 keys did not disable the touchpad as it was supposed to.
It took two different sessions with Dell Techs (totaling almost three hours) for them to finally get the program/drivers that included that check box. The Wife's older Inspiron 1764 had that option from the beginning as does my cheapy little Toshiba laptop.
Now, if I ever have to reload the operation system on that 15R, it will reload the original touchpad program/drivers and I will have to go thru Dell to get the proper one, at my expense.
This is one of the reasons I want to clone the drive while everything is correct and clean. However, as usual, I do not know where to start. I have an unopened copy of Acronis 2009 but apparently that is no good for Win 7.
I went out looking for a later version and am confused why some of them say for multiple computers? Does that mean you can only clone one time with a copy that does not specify multiple computers?
I am seeing here that there might be other cloning options? Any links? I have a huge old Western Digital My Book Drive that is just begging to have a cloned copy of this new computer added to it.
MTboatguy
ya but it works on my wife's Dell and she has windows 7.
Boomyal
...but does she have an inspiron 15R? As previously mentioned, my wife's Inspiron 1764 (4-5 years old) had the feature in the touchpad control software. The otherwise identical looking software on the new 15R did not.
But I digress, any suggestions for online imaging/cloning software for Win 7?
dolluper
WELL did you do it Paragon is one of the fastest I've ever used and free......lets you pick and choose also ....read the destructions ifin your wondering
