Re: ADD fiber glass coat???????
I work at a marina and am currently in the process of tearing out rotted wood from an old boat. I will replace the rotted wood with treated wood and cover it completely with fiberglass and polyester resin. Very few boats have epoxy, most are made of polyester and glass, called FRP, Fiber Reinforced Plastic. Epoxy is excellent, but more expensive than polyester. You can buy polyester resin at any discount department store in the automotive department. Epoxy you probably have to get from a marine supply store.<br /><br />I have never seen a boat where the wood is good but the FRP has gone bad. But your boat may have been made with treated wood. Older boats were not.<br />Anyway, if the plastic looks bad, you may wish to merely sand it and coat it with gel coat. The outside of modern FRP boats is a skin of gel coat.
