Add Lights to ACC1 on 2004 SeaRay 300
cole701
I am attempting to chase the lead wire for the ACC 1 so that I can add some additional lights. The issue is that all of the wires are all tightly bundled together and to further compound the issue if I am reading the electric schematic correct the ACC 1 feed line is Red and Violet, which is also the dang color of all the other feed lines. Has anyone chased this feed line before and if so how did you determine you had the right one outside of metering it out???
Silvertip
Doesn't matter what the feed wire color is as it is already wired. You want to feed lights from the "load" side of the switch which will be an empty terminal on the switch or it will have a pig tail that is not being used.
cole701
I wish it was that simple. Like all of the devices controlled from the cockpit on the 2004 SeaRay 300, the switches are actually an Electronic Interface Module and then the wires come from the Electronic Module... The issue is it is hard to tell if the ACC 1 is even wired given most of the wires are the same color schema (Red and Violet)...
Ayuh,..... Welcome Aboard,..... Do ya have a Test Light, to follow, 'n find the various circuits,..??
What is ACC 1, a toggle switch,..??
There must be some junction blocks there somewhere,.....
Got a picture,..??
