reelfishin
- Mar 19, 2007
- 3,050
Another Starcraft joined the rest today, sort of by accident but it turned out to be a better deal than I had expected.
So far the best I can tell it's a 1960 Voyager, someone has redone the deck with new plywood with two layers of glass over top, and done a poured transom using what appears to be Nida Bond Transom mix.
It came to me on a way too heavy trailer, a 12 roller, 17-21' sized full roller, I moved it to a much lighter, lower trailer which I had sitting idle.
It needs a motor, the last owner bought it for it's motor, which from what I understand was a newer Suzuki. The transom is only 16" tall so I need to hunt down a short shaft.
The question is, what size motor on this thing? It had a 40hp from what I'm told, but the boat is really light and only 15' long. I'm thinking maybe I can get away with a 25hp?
With the 15" transom I'm leery of adding a lot of stern weight with my size and weight. I have a Merc Classic 50 here that will fit, but it's a good bit heavier than what it had.
From what I can find, the Voyager was rated at 10 to 60hp, so maybe a 20 or 25hp will put this thing on plane? For the most part it'll be carrying me and a fishing buddy, plus tackle, so I figure about 600lbs on board tops.
We fish mostly rivers and back bays, so there's no surf to deal with or huge seas, I would never run a boat this size out in open water. The 15" transom has me a bit concerned, but I'm considering ways of raising it but since it's a poured transom, I'm not sure what my options are other than just using a home made jack plate which won't solve the water over the stern issue that would be my biggest concern.
