I have a 17 foot tracker aluminum bow rider.I've pulled up the floor and see that the front holds water. I would like to add a bildge pump at the front so I can get all the water out. I'd like to use the existing drain hole at the back of the boat. Can i just plumb in my drain hose with a T conector at the back hose? If I can then could I also splice in that pump to the same switch so both come on at the same time? Thanks
