Adding a Charging System to Manual Start 35 HP Johnson
SouthCarolina1
Hey! I just got a 1986 35HP Johnson. The motor is a MARS motor. I have not been able to figure out the equivalent Johnson model number, might be E35RCDM? The motor runs great and is easy to start. I am not wanting to convert it to an electric start BUT I would like a charging system. Can anybody give some past experience or advice? Would it just be adding a stator, rectifier, and running battery cables to the rectifier?
Also the motor is missing the intake silencer, does anybody know part number for this?
Thanks in advance.
F_R
Not knowing what is under the flywheel on that model, I'll take a wild, uninformed guess and say that what you suggest probably is correct. Stator, rectifier and wires. But don't try to take this statement to the bank.
I doubt it ever had a silencer.
flyingscott
No intake silencer on that. You need the charging coils for under the flywheel and the rectifier. You do not need to replace the stator there is already a spot for the charging coils.
F_R
Just a matter of terminology. Parts book calls it a stator. Charge coil is the one for charging the ignition power pack. Plate that it all mounts on is a plate and sleeve assy, often called an armature plate.
Reckon that's why they got part numbers.
