Adding a second battery........
1986bassbuggy$@
Would it be possible to just add another battery and just simply add it to the existing battery and battery terminals red to red black to black with a disconnect in the middle of the hot or does this need to be wired a certain way???
Would this be 24v?
1986bassbuggy$@
Re: Adding a second battery........
Just to have a back up battery for my all around white light while night fishing but still have my starting battery charged for the motor and the ability to charge the auxilary batt with the motors stator
Silvertip
Right away we lead him down a path he doesn't want to go down. Yes - you can do what you want to dio. No it does not make it 24 volts. Two batteries in parallel make 12 volts but the capacity of the system is double. Two atteries in series make 24 volts.
But the long and short of this is that you don't need a second battery. Your all around light draws so little current it would likely run all night and the battery would still start the engine. You can certainly add the switch in the hot lead between the two batteries but be aware that it must have a very high current rating and the wires must be battery cable size because the same current that passes through the large battery cables going to the engine must also pass between the two batteries. You can charge the START battery alone (switch open) or both of them (switch closed). You do not need to rewire the light. When you night fish, leave the switch OPEN. Yes, the accessories run off the START battery but so what. You have a fresh backup which all you need to do is close the switch.
