Hey all,
I have acquired a second marine battery for a Manitou toon. The second battery will only be used to power my cd player and led lights. I will NOT have it hooked up to the motor. My question is this:
Can I jump the negative on my 2nd battery to the negative on the first battery so I will have a proper ground? I have a battery shut off switch that the cd player hot wire runs into, so i can cut power at the end of the day. I just need to be able to ground it and didn't want to have to run a long ground cable somewhere. Thanks.
