Re: adding a tell-tale to older Force
That plug is for a pressure gauge, but I have no clue why, or what they were thinking. The Force50HP
might be able to generate 6lbs of pressure. They also made a temp sender that fits into that hole, but by the time it would read over-temp, it would most likely be too late (unless you just happened to be watching it when it climbed up).<br />But it can ruin the flow if this is just 'opened-up', because the block needs that tiny bit of pressure to circulate right.<br />But your idea is intriquing! Maybee you could fit it with a hose, and come out of the top,with a 'jet' of some sort,so that it allways has a few pounds of PSI behind it. I might try this on mine too!<br />Look at the way Merc has thier telltales terminated...they use a fitting that narrows the stream down to about 1/16" (they allways plug-up there). But that would keep pressure in the head,and at the same time, give you a tiny telltale...Hmmm... Tellya what. Let me get back to you Saturday night. I'm gonna make one using a brass pressure washer jet,and some fuel hose, and see if my temp gauge changes (it will be the only time I've ever actually looked at it LOL.<br />It should only take me 10-15minutes this afternoonto rig it up, as I have a good tap-n-die set and hose clamp collection
