Re: Adding a temperature gauge to a small motor help
Gauges need a battery to power the gauge. You'll need to improvise some sort of bracket to hold the sender. If it's a kicker on a large boat with a bigger motor as a main motor, then it would be a good thing to have. If you have a little dingy with the 4 as the only means of propulsion, I wouldn't bother.
