Adding a trim gauge and sending unit on a Force outboard
Recently purchased a pontoon boat with a Force 90 (Mercury Marine) does anybody know of a aftermarket trim sending unit & gauge that would work with this motor. Any help would be greatly appreciated.
jerryjerry05
Need more info??
Year? Model?
The newer 93-99 is Mercury and parts shouldn't be hard to find.
The older is Force and those parts are a lot harder to find.
No Title
OK, the problem I have is that the ID tag on the motor is badly worn. So to know the Year, Model or Serial # is questionable. It is a Force Motor.
roscoe
ignition is cdm modules, which were used from 1996 through 1999, so all parts were from the Mercury/Force era.
jerryjerry05
Mercury bought Force in the early 90's By 95 they were using Mercury's parts.
Before then they used some Mercury and some Force.
​Like Roscoe said that's a Force with Mercury parts.
​Contact Mercury Service for the parts???
​Post on here what you find.
​Good luck.
