I have decided to use two batteries this year after finding myself with a dead battery on the lake once last year. I think I will have engine ONLY on the main battery, and add a second battery to run all other acsesseries, fish finder, trolling motor, radio ect... and just use a home battery charger to keep the charge up on the second battery.
My question is, I just bought a Telex voltmeter and would like to use it on both batteries at different times. So can I use allagitor clips on the battery end of the wires and clip the positive end to the positive battery post and the negitive end to the negitive post, then switch alligator clips to the second battery to check its charge? or will this not work?
As far as wiring the gauge, it has a ground terminal (no brainer) and a (I) terminal I'm guessing that stands for ignition, I'm also guessing that lead would connect to my positive battery posts. It also has an (L) terminal (Light??) can I just connect that wire to Ignition terminal? or maybe put a switch on that wire so as not to have the light on and drain a bit of the battery during the day when the light is not needed?
One last thing the gauge needs a 2 1/8" hole in the dash board to install it, whats the best way to drill that hole? I'm not real big on drilling a whole that size into my dashboard
thanks for the help!!
