Adding Rack and Pinion to old OMC 100HP outboard.
Franki
Hi guys, <br /><br />I just got a cheap deal on a teleflex rack and pinion steering box and cable, about 50 bucks.<br /><br />Anyway, the cable is too long, so I have routed it in a way that gets it to the right places with no tight corners.. I understand how the wheel and stuff goes together,, but am alittle lost with regards to the rear setup.. my old Johnson doesn't have the tunnel hole through the transom brackets.. so I am not sure how to set it up..<br /><br />This is a 100 HP motor, I can't believe even back when it was new it used the old cable/pulleys method, so there must be a way to get it to fit???<br /><br />Has anyone set this sort of thing up before and can you give me some pointers??<br /><br />I am thinking that I probably need to make up some brackets.. has anyone done it before???<br /><br />any tips would be fantastic..<br /><br />regards<br /><br />Frank
DP
Re: Adding Rack and Pinion to old OMC 100HP outboard.
Frank<br /><br />Teleflex makes a couple different transom mounts. Give me your e-mail address and I will send pictures and part numbers.<br /> RPete2001@aol.com
Franki
Sure, that'd be great...<br />frankieh@vianet.net.au<br /><br />Oh, just remembered, the unit isn't teleflex, its Morse, (aren't they owned by teleflex?) the cable is called morse redline..<br /><br />I imageine it doesnt' matter either way at the back because its pretty standard back there.. has to be to fit modern outboards yes??<br /><br />regards<br /><br />Frank
DP
Frank<br /><br />I e-mailed you the page from the Teleflex manual tonight. You are correct when you get back to the engine end the brand doesn't make a difference and Teleflex does now own Morse.
Franki
Thanks BW...<br /><br />Can you believe it?? I have an engine well, but its transom to transom well..<br /><br />so I guess Its figure D for me, which is a shame, cos the other one looks better...<br /><br />Thanks for that, time to ring the local teleflex guy..<br /><br />regards<br /><br />frank
DP
Frank<br /><br />Either mount works great it just depends on your transom as to which one to use.<br /><br />Happy I could help a guy from down under as I am a Foster's drinker.
Franki
Lol, well, there really is no accounting for taste :)<br /><br />I am an EMU Export drinkin myself.. <br /><br />Its actually quite funny, Fosters is one of Australia's best exports, but I don't know any Australians that drink it.. <br /><br />I don't mind it, but there are better Aussie beers to be had,, one thing a country full of ex convicts knows about is how to make a good beer. :)<br /><br />Thanks again for your help..<br /><br />regards<br /><br />Frank<br /><br />PS, does anyone know of a teleflex dealer that would ship international?? anything marine thats imported into Australia has 3 times the price of US...<br /><br />For example, a 88 Bayliner Ciera, my local dealer (good guys actually) are selling it for 50,000 dollars, (about 27,000 USD) <br />And it wasn't even that tidy.. and these guys are one of the cheapest dealers in WA...<br /><br />So I figured since this is fairly small, it wouldn't be that expensive to ship..<br /><br />any tips?<br /><br />FH
DP
Frank<br /><br />Would realy like to taste some of that real Aussie beer, thought Foster's was the best.<br />I have never shipped out of the country but I will check it out Monday when I go back to work. I'll get back to you.
Franki
Good Aussie beers..<br /><br />Emu Export.<br />Emu Bitter.<br />***X (pronounced four ex).<br />Carlton.<br /><br />There are more, but thats a good start..<br /><br />Thanks for looking into it Mr BW.<br /><br />rgds<br /><br />frank
