Adding rear support brace on trailer
erosenwinkel
I have a 1984 Bayliner Capri with a galvanized trailer. The trailer does not have a rear support brace. I would like to add one so I can install a tansom saver (engine de-flopperizer). I don't really care if the transom can hold the weight or not, I don't like it shaking around when I am on bumpy roads, cannot be good, lots of washboard-y gravel roads where I live (please do not comment on the necessity of a transom saver or not, I have heard the arguement over and over:)). I was going to attach a v shaped brace at the rear of the trailer. Can anyone comment about the ability to launch and load with such a brace added on. I don't power load, pull boat on by hand or winch it up. The grade of my boat ramp is about 15 degrees or so (just a guess). As the boat approaches when loading the rear of the trailer is lower and the boat slides up on the fixed rails that go all the way the the rear anyway. I have heard yes and no, yet haven't heard from anyone who has installed a rear brace. Obviously, it would have to be installed so it didn't hang too low to hit the road and not too high to hit the underside of the boat. I would like to weld it on, rather than bolt it on. Thanks in advance. Eric
boat1010
Re: Adding rear support brace on trailer
Pictures are worth a thousand words. If we could see what you are dealing with I'm sure we would be able to help..
erosenwinkel
Daughter took our digital camera to 2 week girl scout camp today. The brace I am talking about adding would be side to side between the main trailer rails leading to the rear of the boat. At the dock the other night I noticed that 50% of the trailer had a rear lateral brace and 50% did not. The closest one I have to the rear is about 4 feet towards the front of the trailer and since I want to mount some sort of engine support brace, I would like to add one at the rear. I guess the question I would need answered is: Is the front of my boat going to hit the proposed support upon loading and unloading?
MH Hawker
i had a old 1968 dilly trailer that was made more or less the same way . i have one i could add to hall and remove to launch i used it for 17 years it worked well
foodfisher
Stretch a line/rope across your idea and imagine what a piece of steel would do. Gonna have to be removable not pita
Ayuh,... Can you winch strap the motor to the boat's aft cleats to do the same job as the brace yer lookin' to add,..??
erosenwinkel
I have to have the motor tippped up to head down the road on the tilt bracket or I will be 2 inches off the road with the skeg of the motor. Motor is a Force 125, about 300 lbs. When up on the bracket it is VERY shaky when I hit a bump. I am concerned that this shaking and jiggling will, over time, rip apart the transom of my 1984 Bayliner Capri. I live in Illionois, our roads are garbage. I am looking for a way to safely transport my boat 20 miles to the water and 20 miles back. My idea is to manufacture a steel rod that connects to a support brace on the trailer and then a cushioned "u" shaped bracket that I can bungy the motor leg to. I know they make a long bent type that I can purchase online, but, I think it looks ricketty and I don't want to waste my time on an attempt.
TMALEGA
I hope this is close to what he is talking about since i have the same trailer he does. I believe, i know it isnt the best pics of the trailer but it should give us a idea of what we can do.
