adding sealant to lower unit?
htuong95
Hi all,<br /><br /> I am getting ready to rebuild my lower unit. When I put it back, do I need some kind of sealant on the mating surfaces of the lower unit to the leg? I remember reading something about adding non-hardening sealant somewhere. Do I need to put sealant anywhere? Thanks.
roscoe
Re: adding sealant to lower unit?
Depends on the make and model motor you have.
htuong95
I have a chrysler 1976 4hp sea king motor model # vwb 520004.
roscoe
Sorry, I don't have a manual for that motor.<br />Was there any evidence of sealant in there when you took it apart?<br />Hopefully someone with a manual will come along and provide answer.
spartanpele
I would say, yes, use some marine type sealant (form a gasket.) Also put some sealant on the threads too. And no, not the hardening type used for repairing cracks in metal.
eurolarva
clymer manual says to use a bead of RTV along the gearcase mating surface and also as spartanpele says on the mounting screw threads.
