Adequate Tools: specifically what should I look for in a tachometer
zpbruno
I got mildly burned by a cheap compression tester from Amazon that was giving me values much lower than truth. I verified this by "renting" a compression tester from a local auto parts store. So the compression tester is getting returned.
I also bought a cheap hourmeter/tachometer that gives tach results with very poor resolution that hop all over the place. I want something better: what should I get? I've got a dmm that measures frequency and that works ok on my outboard with a tacho output but still seems jittery. Seems like there should be better choices.
alldodge
Stick with old name brands and you should be good
OTC, Snapon, Craftsman, IR,
Chris1956
The tach signal of an OB is different than a battery coil ignition like a distributor based auto ignition. Therefore a standard dwell/tach will give incorrect results.
An OB tach does count pulses, but I do not know if the freq. setting on your multimeter will count is correctly.
Why not get an OB tachometer? If you don't want to install it into the boat, make a stand for it..
for diagnostics, a good laser tach
for mounting on your dash, a VDO, VeeThree, or Faria
