adhesives and lubricants
i57chevy
rebuilding an evinrude v4 115 hp crossflow
so far this is what I see that it calls for:
omc gasket sealing compound
omc geal seal 2
omc locquic primer
omc needle bearing assy grease
omc moly lube
omc triple guard grease
omc nut lock thread locking adhesive
omc electrical grease
These are the ones that I have. Can anyone tell me which one to use for what?
super 300 form-a-gasket 80057
three bond 1184
thread locker red 27100
form-a-gasket 80015
dielectric grease 81150
Also, I'm putting the same connecting rods back on. Do I need the special tool indicated in the manual for the rod caps?
Thank you.
Billy
i57chevy
Anyone willing to help me out? Please take a look at my questions.
jimmbo
I doubt a Red thread locker is what OMC had in mind when it came to thread locker
Dielectric Grease might be useful for a Rectifier if it needed a Heatsink
I'm not going to comment on the Glues/sealers you have on hand...
The Tool mentioned, is used to ensure the Connecting Rod Cap is properly positioned before being tightened down, however many of these engines are assembled without it. Some even last awhile
I started putting these together long , long time ago.----Do not have the factory tool.----Never had a rod bearing failure.
