Re: Adjust Air/Fuel Ratio
It seems that the bottom carb is not getting fuel. Does anyone know how to help?
After pumping the fuel primer bulb up hard, remove the drain screws from that carburetor to see if fuel is or is not entering the carburetor float chamber.
If fuel is present, your present question has been answered. Now.... what exactly is the engine doing or not doing?
The basic trouble shooting procedure is to check the compression first... what are the psi reading of all the individual cylinders?
Secondly, with all the spark plugs still removed, check for proper spark which should jump a 7/16" gap with a strong blue lightning like flame... a real SNAP! Does it?.... Note that the 7/16" gap is important!
