Engine: 1999 Volvo Penta 4.3gl
190 Horizon
The engine idles very low and unless it has been warmed up for about 30 minutes (giving it gas without prop engaged) it wall stall out while in neutral. Also, when I put the drive in gear I have to give it allot of gas or it will stall out. Once it is in gear it runs fine.
The issue has gotten progressively worse, the constant stalling makes maneuvering difficult (especially while docking!)
The high octane gas is new and the fuel filter has been replaced recently.
Can the throttle be adjusted and have higher RPMs while in neutral? If so, is this simple to do? Any other thoughts?
190 Horizon
