nateo
- Apr 13, 2014
- 352
ok, so some of you may remember my story of spun coupler at wot results in bent valve. Well I'm still having some issues with timing and rpms. When trying to adjust timing I either end up with to low rpm and it stalls or high rpm and high idle. Although it appeared to be running well at the top end the rpms were too high, 4800 instead of 4600 as noted on engine. The starboard side head (which I did not pull) has high compression in one of the cylinders. I believe it was around 169 instead of 150, all others are 150 as they should be. 1. is this likely the source of my high rpm/timing issue? 2. Is this likely just a issue of valves needing to be readjusted properly or might I have some other issue such as a bent or sticky valve?
