pete44
- May 7, 2005
- 189
Hello. Have an 87 Searay with 3.0L 181 ci with alpha 1 drive..had transom redone and engine was out and back in.. trying to lower my idle (in gear) rpm from 900 to 650 to 700 recommended rpm ..tried adjusting throttle cable adjustment screw..got it down to 900 rpm (in forward gear)..there is another screw on port side of carb (at throat)..I didnt see any other screws to adjust on carb...I looked at mercruiser manual and it states "once engine warms up bring back to idle speed..shift into forward gear (idle position)...disconnect throttle cable brass barrel(spacer)from anchor stud...I can do this on my drive way with muffs but is it necessary to remove throttle cable spacer??? and would it be better to do this while in water..(with a water load..so to speak)??? Also,could I adjust this without drive engaged???...sorry so long...Thanks,Pete44
