les morgan
- May 11, 2007
- 49
service manual says to hold carb upside down and adjust needle actuating
lever to have the bottom of the float at 1/4" from carb body bowl ring, no
problem. but then it says to turn carb over and adjust the drop of the
float where it is 1/64" from bottom of float to top of the main fuel jet, do
this adjustment by bending the float tang. Problem is old float had a metal
float tang and the new plastic float has a plastic tang that cant be bent
to adjust drop. Do you trim the tang to get the desired drop? My float is
1/8" from bottom of float to top of the main fuel jet.... Is this close enough?
Les
Les
