50 ETLK 6H5 L 412845 - Yamaha OEM manual states to adjust the oil pump to the carb at WOT. My question is regarding the oil pump lever postion. Forward towards the carbs is max oil pump at Wot? Picture is unclear and description is dark and inconclusive. Oil pump lever swings forward(towards the carbs) and back (towards the head). Is forward max oil pump at WOT? Need to know before next outing. Have been using premix 50 : 1 in the meantime. Nylon connector was broken so I do not know original adjustment. Thank You for your replies they are greatly appreciated.
