Re: Adjusting points???
The rubbing block must be on the high lobe of the distributor cam (points open) this would be the gap setting position, turn the flywheel by hand and observe the rubbing block while also watching the points open, the rubbing block will remain on the high spot for a few degrees of turning the flywheel before it drops back off.
