Re: Adjustments for higher elevations 69 85hp
No, but my '05 pickup truck which is used to 800 ft fell on it's arse crossing the 8500' mountains around Alamogordo, NM.
So if they aren't expensive and you have the time.....since so far you don't seem to have any other options, you might purchase several sizes and experiment. The tool doesn't look too difficult to make from a screwdriver.
Then put on that 15" prop the dealer suggested.
I'd start with half the area.
Here's an example.
The late '90's 100 and 125hp Merc engines are being compared (from my service manual). We have a 25 hp increase with the same number of carbs/cylinders...course other things may change too, like maybe a different carb to change the venturi air flow volume, but.........
The main jets are .046 and .066 inches in diameter respectively (these engines happen to be running 4 carbs on 4 cyls. Calculating area, the area of the 125 is twice the area of the 100 even though the hp only went up 25%.
You can't just halve the diameter since area is what lets fuel thru the hole and area is squared in the calculation so it goes up or down much faster than the diameter change....area = 3.14 x [(dia/2) x (dia/2)]. [3.14 is usually symbolized by the (greek letter pi)].....so for the 100 hp jets @ .046 diam, area is calculated: 3.14 x [.046/2 x .046/2] = .00167 sq in. The 125 hp @ .066 have an area of .0034 which, is as I said, about double.
That should give you an idea.
Hopefully an altitude guy will jump in here and give you some feelers.....
Hello QC, BruceB, where are you?
Mark
