advice needed on boat storage
jinx
I would like to get something for my boy to take out fishing--without using Dad's boat.<br /><br />He's gotten good grades and doesn't demand a lot of upkeep like his brothers, so a little pat on the back might be in order. <br /><br />My problem is this. Our place is wooded. I have a pier that is nearing the end of its life cycle and a ramp. Instead of using a boat lift I just pull my boat up the ramp when I'm not there.<br /><br />It doesn't leave any other room to pull anything up though.<br /><br />My options so far are:<br /><br />An lightweight aluminum v-hull that I could just pull up the ramp and leave it.<br /><br />Advantages: fairly cheap, second hand ones are available, and its a simple solution.<br /><br />Disadvantages: It's a tidal creek, so the water is salty and would probably be hard on the aluminum. Also, while for the first year or so Dad's word would keep him out of the big water (the Rappahannock is 2 mi wide at that point) that wouldn't hold forever, and I'm not sure that is what I want him pushing his luck in.<br /><br />Option 2: Carolina Skiff, bottom painted and left in the water in season.<br /><br />Advantages: solid, self-bailing, sea-worthy and forgiving. Reasonably priced, unlike a whaler, which would be great except for the cost.<br /><br />Disadvantages: bottom painting a nuisance? Is outboard theft (tiller type) a real risk? Davits on the pier might be an option, but I really don't want to strain the aging pilings (hull weight 250# plus motor). I hadn't planned on replacing the pier for another 4 years or so.<br /><br />Any thoughts. Maybe a couple of heads together can figure it out.<br /><br />Thanks<br /><br />Jinx
roscoe
Re: advice needed on boat storage
How about placing a trailer at waters edge, and winching the boat up onto the trailer when not in use. Home made lift. Will probably need to extend a set of rollers off the back of the trailer, down into the water, but that is easily doable. And remove the tires and axle to lower the trailer.<br /><br />Some commercial systems are available, but you could easily do it yourself, providing the boat you buy comes with a trailer.<br /><br />
jinx
Thank you for the response. Maybe I can do something along these lines...homemade marine railway!. Problem is the wooded shoreline and the topography. My open area is already occupied by the pier and existing ramp. <br /><br />Access to the ramp is an old rolling road through woods. Pretty enough but a logistics nightmare.<br /><br />Jinx
