bonz_d
- Apr 22, 2008
- 5,276
Some might remember that The Alumacraft I bought last fall had a blown 1988 Evinrude 70hp on it and after disassembly I found that the splines in the crank are wiped out otherwise the engine is in pretty good shape.
Well I've been contemplating rebuilding this over the winter after not getting much interest in selling it out as a parts engine. After looking through BRP's website I was able to determine that the cranks and piston assemblies from the 60hp, 70hp and 75hp all have the same part number all the way back to 1983. Though I also see that there are a multiple of numbers for the crankcases throughout these years. Anyone have any clue as to the difference in these crankcases? I have also noted a few changes with cylinder heads.
Anyways the thinking is that there are always engines available on CL with a blown cylinder and I should be able to aquire one reasonably cheap to salvage a crank from.
So is it worth the time and effort? Right now I have a line on a 1983 75hp that is very clean and runs but has low compression on one cylinder and also a 1986/7 60hp that is complete and is said to run but runs rough and is not quite as clean. Either can be had for a couple hundred bucks.
