mercurymang
Master Chief Petty Officer
- Jul 14, 2012
- 853
I recently posted a thread regarding a boat and motor i recently purchased. I had seen steam and was concerned that there may be an issue.
http://forums.iboats.com/showthread.php?t=583370
I decided to tackle the problem and after some hesitation began removing the bolts to get the exhaust cover off. All things considered, it went pretty well. I got the cover off and found the problem to be the thermostat diaphragm. There were a total of 18 or 19 bolts and I got all but 3 out cleanly. The remaining three were the most interior close to the water jacket and i ended up snapping the heads of them. They have about 3/8 to 1/2 inch of bolt sticking out and thought for sure I could get them out with some heat and vice grips but have not been able to get them to budge.
I decided to drill and tap the worst one and was for the most part successful but I did booger up the threads a bit trying to extract the old stainless remnants from the aluminum.
So my question is this. Should I go ahead and do the same for the other two and go back in with helicoils or should i pull the powerhead and take it to a machinist who can do it some justice.
Am i right in being so concerned over these three bolts or is this not that big of a deal?
Here is a pic of the three bolts. You can see them running vertically in the center.
