les morgan
- May 11, 2007
- 49
I have a 1999 Sprint bass boat that has developed a few elect. problems.
About 3 months ago my aerator pump which pumps water into the live wells
quit working. I removed the pump and checked it, was bad. So I replaced
the pump, but when I tried it with the switch- nothing. I can run a hot wire
to the battery and it works fine. Now I started having the same problem with
the recirculation pump. Pump went bad but when replaced I get the same
results. The lights on the switches come on but the pump will not run. The
switches look the same but have different #s. Both say Carling but the #s
are VJD1 9842 and VJD1 9747. They have 8 terminals on the back but only
7 are used. I have a volt/ohm meter but do not have a diagram for how they
are supposed to operate. If anyone can tell me the way to test for a bad
switch or has a diagram of the switch operation, then I can tell if I have a
switch problem or a wiring problem. Also it has switches for the same operations on the bow panel, but will not work from these switches also.
Any help will be greatly appreciated.
Thanks
Les
Thanks
Les
