It's not hard. I replaced hoses and motors on my '85 Ranger 340V. If yours is factory stock, don't expect to get the hoses off easily. I had to cut mine off which is why I decided to replace everything including the PVC piping. I also eliminated the valves Ranger uses as I couldn't afford the $30 apiece it was going to cost to replace them. Now I just use plugs in the live wells. It was surprisingly inexpensive to just replace everything, just be sure and use a food grade braided hose. DO NOT use heater hose as you'll kill all your fish. Unhook the hoses from the livewell and the fittings on the transom and it'll all come out in one piece.
I found your post interesting because you eliminated the valves and just use plugs. I have an 1982 V-375 which I think is quite similar to your boat. I want to use the front livewell simply as a cooler and the back one as a livewell. I could eliminate everything up front and just us a plug and drain so that one would not be a problem. I guess that I don't understand livewells (never had one before) but if I were to use a plug in the back livewell how does if fill? would the aerator pump fill it via the aerator tube on the top of the well? If this would work it would be great.....just put the plug in, turn the pump on, and be done with it. On the other hand, it sounds too good and simply to really work.
Please advise,
Don
The well still fills from the aerater tube and you leave the back unplugged for drainage/overfill. The hole they are plugging is the one in the bottom of the well.
If the well is full and then the plug is pulled does the water run out through the pump or is the drain connected behind the pump or some other way?
Thanks,
Don
the plugged lower hole is the drain (and gets removed to drain the livewell)
