Huntingbill
- Sep 5, 2019
- 9
Installed a 2000 Evinrude 35hp 3 cyl with controls,
Shift/Throttle cables not installed, engine in neutral, controller in neutral, tilt works but will not crank.
Deadman installed, power to solenoid. Engine down, no water to unit as I just want to get it to crank, no gas, oiled cyl as it just came out of storage.
I do not have the under dash wiring installed so wires to Volt/Tach etc not hooked up. I should state it has external battery cables if that makes a difference. What am i forgetting?, Does the engine feed voltage back to controller ignition switch to start? Does the wiring harness require a power relay? Thanks for any help
