Re: After It Runs Awhile
There are lots of possibilities. If I had your symptoms, I would use a systematic approach to narrow it down
To test ignition, I would check to see if ignition voltage is dropping/missing during engine bog/stall. This can be done in a variety of ways. I prefer to check secondary voltage in the spark plug wires with a SmarTach meter. You can also use a timing light or dva meter to test for ignition failure during engine bog/stall. I find the SmarTach meter is more convenient and more conclusive in eliminating failed ignition as the problem. The following website can help in groubleshooting the ignition.
http://www.homestead.com/dolphinmarineservice/Ign5.html
If it is not an ignition problem, I would clean the carbs to make sure none of the passages that are part of the idle circuit are plugged up.
This is what I would do. Others on the forum may have additional or better suggestions for you.
Good luck
