after market brake dust shields --- hey Larry_F
llfish
Re: after market brake dust shields --- hey Larry_F
The ones I put on my Escape work great.
JB
They work pretty well, but:<br /><br />They do reduce the airflow around your disks. Most of the time that is no problem, but if you get into a long downhill when you use the brakes a lot it may become a problem.
Reel Poor
Alot of this depends on the type of vehicle they are to be used on. Ventelated rotors seem to hold up well with the use of the dust shields, but non ventelated rotors are commonly warped due to excessive heat retaind in the rotors. <br /><br />Different brand shields may yield different results. Due to the amount of air flow.
Chief101
What is the advantage to having dust shields? I've never even heard of them. Chief
Reel Poor
Chief <br /><br />Its designed to keep the brake pad dust from getting on your purty wheels. :D
Skinnywater
Your brake pad wear will increase. On Mercedes the pad life will cut in half.<br />Rotors warping on a Benz is almost non-existant but with dust shields it's common.<br /><br />The dust sticks to the inside of the shields. When I hit the lugs with an impact gun it loosens it all. It leaves a pile of dust under each tire I remove.<br />I hate them plenty.
rickdb1boat
They work great on my pick-up. Got em' at Whitney. But then again, I really don't let much dust stay on for too long anyway. Keep it pretty clean... ;) ;) <br /><br />
Chief101
Rick, I had a pickup like that a couple of times, then I took it off the lot and used it. Never again do they look new when I gets ahold ofem. ;)
tie_one_on
Larry F-. What brand did you buy? How long have you had them? Thanks.
tie_one_on
Hey Larry, what kind did you buy? How long have you had'em? Thanks.
