AFTER MARKET FUEL PUMP
RTUTTLE1
1992 200 HP JOHNSON I BROKE THE INPUT TO CARBS PLASTIC PART HOSE HOOKS TO . CANT FIND THAT PART HAVE TO PURCHASE WHOLE VRO AND FUEL PUMP FROM JOHNSON $300.00. FOUND A MECHANIE THAT SELLS JUST A AFTER MARKER FUEL PUMP LIKE YOU SEE ON 10 TO 40 HP. JOHNSON HE SAYS IT WILL WORK ON 200 H.P. JONHSON WHEN USE 50-1 OIL GAS MIXTURE<br />WITH VRO DISCONNECTED. HAS ANY ONE REPLACED A VRO FUEL PUMP WITH A REGULAR FUEL PUMP WITH OUT THE VRO HOOK UP. THE AFTER MARKET HAS A PULSE AND IN AND OUT FOR MY GAS LINES??? AFTER MARKET=$45.00..<br />WILL IT WORK ????
Dhadley
Re: AFTER MARKET FUEL PUMP
See that light at the end of the tunnel?<br /><br /><br />Its a train.
dajohnson53
Just a suggestion - have you tried repairing the part you broke? I broke a plastic part on a carb. Cleaned it thorougly and repaired carefully with JB weld, shaped as necessary with a Dremel and it's as good and strong as new. The tricks are: finding the pieces, getting good and clean (I sprayed with carb. cleaner, brushed with a toothbrush, and dried thoroughly, then making the repair in such a way as to not clog any passageways, and shaping enough on the exterior so it serves it's function. Just a thought before you get into $$ and hassle.
RTUTTLE1
you can use jb weld on plastic ? i broke a hose connecttion elbow coming out my fuel pump- have to buy whole fuel pump $300.00 a johnson fuel pump cost 45.00 with out vro ?? has anyone just bought a regular johnson fuel pump to work on a 175 to 200 hp. johnson???
Dhadley
Those small fuel pumps used to come standard on 175 and 200 crossflows. In pairs. They were never meant to be used on a V6 looper.<br /><br />There is a "VRO" type pump that does not have oil injection that will work. But its not 45.00 either.
D
DJ
Guest
I smell a MELTDOWN with the aftermarket part.
Dhadley
I'll stand by my first reply. And I think the light is getting brighter.
dajohnson53
Originally posted by RTUTTLE1:<br /> you can use jb weld on plastic ? i broke a hose connecttion elbow coming out my fuel pump- have to buy whole fuel pump $300.00 a johnson fuel pump cost 45.00 with out vro ??....
JB Weld FAQ <br /><br />Of course I don't know if it would work on your particular plastic part, but I've repaired many plastic parts - outboard and other - with JB weld. They say it's resistant to gasoline, and I've found it true, so far. The trick to any fix w/ JB weld is to get it perfectly clean and dry and then to set up the project in such a way that the epoxy material will stay put and you can hold and/or clamp it steady while it dries. I've sometimes used tape to clamp and hold things in place, and if it doesn't matter, just ends up permanently attached. Or I whittle and/or grind the tape off later. Also, if there's interior passages - they need to stay clear of course, but sometimes you can drill things out aftwerward. I generally try to avoid this by using a toothpick or pin to be as precise as possible when applying the material when I'm mating broken surfaces. For the exterior parts, it's not as critical because it's pretty easy to grind and shape with a dremel and the right bit. Just like a dentist working on a crown!
guyo
good luck i am going through a similar problem and every mechanic wants top dollar which i dont care about but these people say its going to be a 2 to 3 week wait,then you gotta figure 2 to 3 days for parts and another 4 to 5 days for them to get back to the boat. to make a long story short its at least a month.
RTUTTLE1
dhadley am#685 - if mines a crossflow (separate carbs??) can i use the after market fuel pump or will it be to little to get proper gas to carbs> i dont want to hurt motor?? also whats this other fuel pump you talked about $150 better $300 ??<br />thanks for your responds. 200 hp jonhson fuel pump problems..
CATransplant
Boy, I wouldn't try to fix a fuel fitting with JB Weld. Vibration...fuel spewing inside the outboard. Sounds like a disaster waiting to happen.
Dhadley
Your motor is a looper and it must maintain proper fuel pressure to live. The no-oil fuel pump for a looper is 438402 -- I THINK. Ask your dealer to look it up to make sure. And yes, I do believe they're around 150.00. 165.00 if I remember right. But again, ask when you order it.<br /><br />Truthfully, I'd rather have oil injection on that motor. Its a lot safer.
