aftermarket or OEM prop?...difference?
87VIP
What are the differences (if any) in an OEM prop and an after market aluminum prop such as Hustler? I have a 1987 OMC 2.3L 4000RPM WOT. It has a 13-3/8 X 17 on it I was told I could go to a 15 pitch and get a better holeshot and a little more mph. :confused:
D
DJ
Guest
Re: aftermarket or OEM prop?...difference?
toby,<br /><br />I do not know what kind of boat this is on, but 4000 rpm at WOT is too slow for that engine. You should be able to hit 5500 rpm-MINIMUM.. RUNNING IT TO SLOW LIKE THAT WILL KILL THAT ENGINE.<br /><br />You can figure that each inch of prop. pitch is worth about 200 rpm, either way.
87VIP
The boat is a 1987 VIP Vision 17' I might have stated the RPM wrong, should I be looking at the RPM range WOT fully trimed?
