Aging float cork on alcohol -- Mythology?
halmc
Got me a shiny, new-to-me '57 Fleetwin replete with a shellacked(?) cork float in the carbie.
It'll soon be getting its first dose of heavily subsidized, midwestern methanol spiked, unleaded gasoline.
Should I worry about my cork?
tashasdaddy
Re: Aging float cork on alcohol -- Mythology?
seems like there is a replacement float that will work, but cannot find #.
JB
That is ethanol, not methanol.
tx1961whaler
I still have one motor with a cork float in it. It is still in good shape, but I'm keeping an eye on it as an experiment. Not a good experiment, i"m afraid, since I pull the fuel line and let it run out of gas at the end of a trip.
Maybe someone with a known good cork float lying around on a bench will perform an experiment and let the float soak in a sealed glass jar with ethanol pre-mix in it to see what happens. Note how high the float floats at the beginning of the experiment, and see if it gets gas-logged later.
ezeke
I can tell you for fact that I have had to replace all of the cork floats in my old OMC steel gas tanks.
The solvent for shellac is alcohol; that has not changed.
CATransplant
Alcohol dissolves shellac. Remove the cork float. If it's in good physical condition, let it dry completely, then coat it with cyanoacrylate super glue and let it dry completely. Alcohol doesn't affect that stuff.
F_R
The guaranteed, fool-proof, and simplest way to fix the problem is to put a new float in it. The new one is part number 396514 and is made of an alcohol-proof material. The problem will be solved.
halmc
Thanks, that's very helpful.
Thanks. Googled and ordered!
Thanks, that's a clever trick, I'll follow it with the float in the gas tank.
