So, outboard in question is a 78 115hp
Took the lower end off, broke the head of one of the 4 side bolts.
Bolts are stainless steel grade-8's smuthered with lock-tight.
first thing I tried was vise grips, then i tried hitting it with the PB-Blaster. Then I tried the torch. then I tried welding a nut onto it. Then a pipe-wrench. then I drilled a hole in it and tried to use an expensive easy out. which promptly broke off inside.
So..... I'm screwed? There is no way this bolt is coming off. whatever was left of the bolt tip is now gone, i have a bolt with an easy out wedged into it.
So, I'm thinking leaving it broken is out of the question?
so.... what about drilling it out completely, and tapping some larger threads into it.
where would I get a step-larger bolt? and how would I fit it into the lower unit?
Ive never done this before. But i don't want to scrap my project because of a bad bolt.
