air box
60hpomc
I have a 60hp that I rebuilt because previous to my ownership it sucked up a piece of washer and ruined a piston. Is this common to happen again why is there not a air filter or at least a screen on the air box? Any suggestions
Chris
jtexas
Re: air box
as I understand it (this maybe just an urban myth), outboards have no air filters because on the water, airborn contaminants are seldom seen in enough quantity to penetrate the cowling and cause a problem.
You talkin bout a metal washer? Must have been a tiny fragment. Thanks for sharing - there's a lesson in there somewhere........
Where I work, when an engine is harmed by something it ingests, we call it FOD (foreign object damage), and we avoid it by trying to keep the runways clear of debris. The strangest example I know of was an engine that just disintegrated; analysis of the debris revealed an alloy foreign to the engine, but commonly used in tools - somebody forgot to count his wrenches. Then there was the guy who forgot to set the brakes on his rolling tool box - lost everything to an engine during a test run-up.
Evinrude Boater
Re: air box
My 75hp has plastic screens over the carb inlets but they only stop something bigger than a teddy bear. I often wondered the same thing. I'm always stuffing rags in the throats when working around the engine to avoid losing something down there.
