Air Compressor Question
nomoe99
I have a 3 Gal. pot air compressor.
I pulled the dip stick and there is oil on the bottom of it.
But the tank is very low.
What kind of oil do I put in it and how much in the tank?
Thanks,
nomeo99
jbd
JustJason
Re: Air Compressor Question
gonna sound like a smart arse answer but you need air compressor oil. you can find it at home depot, lowes, sears, etc.
Fill it until it reaches the mark on the dipstick. or, if you have a sight window its usually to the middle of the window.
nomoe99
Sounds like a good answer to me, not a smart alec one!!!!!!!!!
will check at Norman when I go there Wed.
Thanks
nomeo99
JustJason
Should have said this yesterday, but if you can't find "air compressor oil" you can usually substitute it with straight 30W non detergent oil.
You should also get in the habit of changing it once in a while to, as you'll get a little water in the oil over time with use.
rbh
You should also look at cleaning the air element/cleaner as well some are foam, some are paper which will need to be replaced.
Tim Frank
Check the owner's manual for oil spec and fill instructions.
