Air conditioning 2002 24 foot Bayliner cierra
frankxyrn
I can't turn on the airconditioning. I flip the circuit for air conditioner/heat, but what do I do next? Is there another switch to flip?
Re: Air conditioning 2002 24 foot Bayliner cierra
Ayuh,... Is it powered by shore power,..??
Is it plugged in,..??
frankxyrn
Yes power on (shore) frig and microwave work. There must be another switch to run AC, rirgt?
FunInDuhSun
Um, adjust the t-stat?
A/C won't kick on if it's not set.
Your stat might have a couple different switches that need to be in the proper position.
Try opening the t-stat cover.
Fireman431
Shore power working.
A/C breaker on.
Water pump seacock open
Water pump circuit breaker on.
Thermostat set to cool mode and temp set at least 3 degrees less then the existing room temp.
