Greetings,<br /> Our 1993 Yamaha 9.9 outboard isn't peeing. We ran it to see if there was a thermostat that would open up and let the stream go, but although no water was exiting, she wouldn't heat up either, and that after powering up the channel and back. Like a couple of clowns we were watching the wrong hole....the one aiming downward on the aftmost side, in the metal casing, about mid height on the engine. A mixture of mostly air and a spritz of water were steadily trying to get out. The actual water (peeing) exit only had a few drops coming out intermittently, but it was warmer than at the other hole. Is this a classic case of water pump failure? And what is that other downward aiming hole for? The manual doesn't even mention it although it is marked on the diagrams.
