Re: Air Filter for an Outboard?
walleyehed, there are two versions of these covers available. One is for storage, and one is for travel. It appears you're using the storage cover for travel. Or a different brand. <br /><br />The one for storage is made out of a thicker, stiffer material and has no soft/fuzzy inner liner. I think the material is called Sunbrella. These covers are more expensive.<br /><br />The one for travel is made out of thinner, more flexible material that includes a soft/fuzzy no-scratch lining. I think the material is called Softliner. These covers are actually less expensive than the storage one's. A cover for the 25 Merc will run about $110....cheaper than a carb rebuild or engine overhaul.<br /><br />Both cover options are perfect custom fits, no matter the make, model, or year. Each one is made individually and specifically for your outboard. They will even custom fit the cover if you have a hydrofoil or Dolefin on the cav plate. They do not flap or move while traveling. In fact, they go on very tightly and use zippers and Velcro to snug them up.<br /><br />I've used these covers for years, traveling in the worst conditions Canada and Alaska have to offer. Never once have I had the covers chafe the paint off my outboards.<br /><br />I just hate to see a guy stuffing things in his carb to keep the dust out (what about the rest of the motor?), when he can get a complete cover. Cheap protection.
