Air-Fuel mixture setting
MaccaMckeon
Can anyone confirm what the correct number of anti-clockwise turns from seat is right for fuel-air ratio setting on my Johnson 35hp 89model I think (S/n is 696289).<br />I saw that an older model was 1&1/2 turns out.<br />Cheers,<br />Macca.
BoatBuoy
Re: Air-Fuel mixture setting
The setting could be different for identical motors. That's why it's called adjusting. See below.<br /><br />"(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br />(J. Reeves)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.<br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /><br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.<br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.".....Joe Reeves
MaccaMckeon
Thanks,<br />I'll give it a go today.<br />The reason for adjustment is the motor keeps cutting out when I change the control from forward gear into neutral. And more frustrating is it idles fine until I engage forward gear then it dies unless I'm quick and keep the revs up enough. Note, when at home out of water, motor runs great with no problems.
