I have a 3 Hp motor for my dinghy. Is there a procedure for getting an air bubble out of the line?
I have taken the carb off and held it well below the gas tank but the air bubble will not go pass the cut-off switch. I have drained all the gas and poured it back again and the bubble reappears after a while It appears to me that the carb bulb may not fill completely with gas and eventually the air bubble gets out and stalls the engine. I replaced the normal tubing with a transparent tube so I could see why the motor keeps stalling after running for a couple days. I'm pretty confident I don't have any air leaks in the lines. If I leave the motor sit for a while enough gas gets by the bubble and the motor will run again but can't get enough gas pass the bubble to run more than a couple minutes.
