Air rail fitting need
dlr123
I have a bad air rail elbow insert fitting. This fitting sends air to the fuel pressure regulator. Nissan does not have this part in their part book. They told me i would have to buy the entire fuel rail. Nissan nsd90a 90 hp tldi engine. Anybody know where i might be able to find this fitting?
pvanv
Is the fitting cracked? Could it be soldered? If it is leaking where it attaches to the plate, you will need a new plate:
3T9100800MAIR RAIL$366.28
pull fitting
fire up brazing torch
repair fitting
re-install.
dlr123
I may have to try my luck with torch. I can solder copper pipe, so maybe
use a brazing rod, or silver solder at a minimum.
do not use lead solder (not enough strength)
