Slightly Stewpid
- Mar 15, 2015
- 29
2003 Volvo Penta GXI with a blower. 300 hours on the engine. Cruising at 4000 rpm for 15 minutes, everything was running great. Pull the throttle back at the mouth of the harbor and immediately I get the alarm. The temp gauge was reading cool. The oil pressure was good. The only thing I can think of was the alarm from the exhaust temp sender. I cut the motor and lifted the hatch. No steam in the engine compartment. Tried starting it up and nothing. Waited 15 minutes and I could get the engine firing by pulling it out of gear and giving the boat some throttle, but it was very roughly at idle. Limped back in 10 minutes to the dock with the alarm sounding every 5 seconds. This was yesterday.
This morning, I went down to the boat and fired up the boat by taking it out of gear and giving throttle, once it fired out came black smoke and soot. As the engine warmed up, I continued to throttle back until the throttle was at idle. After it warmed up, the boat ran very well when I took the boat to the fuel dock, and around the harbor. It fired right up 4 or 5 times today(I did not need to pull it out of gear and give it throttle). What happened? Is there anything I need to check or get looked at?
