Alarm problems
lovnmyboat
Alarm problems
I have a 91 200 xri....the alarm started going off intermittently. Sitting on the trailer (in the water) idling in neutral, running up the rpms to 2000 to 2300 (for a fairly lenghty time) alarm will not sound. Take it off the trailer up the lake, it sounds intermittently. I checked the sensor in the oil tank, no continuity, appears to be good. Took bottom end off to check impellar, good shape, replaced about 20 hours ago. What is the next step? It just started at the end of a full day of boating. Any suggestions?
FranksMerc
Re: Alarm problems
Re: Alarm problems
Could either be a low oil alarm or overheat alarm. On mine the low oil beeps, the overheat is steady. A manual will tell you how to check the oil sensor.
lovnmyboat
Re: Alarm problems
Re: Alarm problems
It is an intermittent beep not constant. I appears to be oil related. I have checked sensor in tank.....what should I test next?
